Blue_Blood
- Nov 3, 2015
- sarnia
- 2010 yamaha apex ltx gt
Just wondering my 2010 apex ltx apparently had some clutch work done to it before I bought it and I'm now looking into a kit because I think I've been robbed of top end speed 105 mph max just wondering any info on stock spring colors and helix maybe weights to see whats even been done to mine ?
d-day
- Nov 23, 2015
- Phillips WI
- 65-15 Yamaha & misc
Go to top of this page click ty tech. click on snowmobile tech. top line has stock specs for multiple sleds and years. If you cant find let me know and I will post specs here for you
Blue_Blood
- Nov 3, 2015
- sarnia
Wow that's amazing best info I've seen in a long time thanks a lot just like I expected not the rite secondary spring any idea how the 60 degree setting works
Blue_Blood
- Nov 3, 2015
- sarnia
Also doesn't give a helix number I'd also like to make sure it's correct
d-day
- Nov 23, 2015
- Phillips WI
Again in tech info. under clutch and jetting scroll down cam angles lists your 51/43 stock cam with ID # 8FA00. scroll to twist angles chart pic shows all angles you can twist your helix which adds or subtracts spring tension. In your case 60deg would be spring position 3hole on secondary 3hole on helix is stock.
d-day
- Nov 23, 2015
- Phillips WI
I checked my 06 and 15 Apex helix ID #s both the same 8BVFA and those run 51/43 angle as does yours in stock form.
Blue_Blood
- Nov 3, 2015
- sarnia
Yes I didn't see where it said hole 3 and 3 for the spring but that's helps mine has a black spring in the secondary and by this info should be white and I'm going to look into the number of the helix because I remember the first owner saying something about it
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
All yamaha springs are black. there should also be a small spot about mid spring with another color which tells you what spring it is.Yes I didn't see where it said hole 3 and 3 for the spring but that's helps mine has a black spring in the secondary and by this info should be white and I'm going to look into the number of the helix because I remember the first owner saying something about it
Blue_Blood
- Nov 3, 2015
- sarnia
Ok guys thanks I'm going to go have a look and see what's been done and then post some pics
Blue_Blood
- Nov 3, 2015
- sarnia
Well found out what's in mine springs are stock and are set to the proper degree everything looks ok but the helix is not the rite number and is shimmed out with washers not sure why doesn't look rite I have pics but it won't let me post them says there to large
Blue_Blood
- Nov 3, 2015
- sarnia
I have a 8bvfa helix on mine and it's shimed out with washers no idea why but suposed to have a 8FA00 and I want it rite If anyone has a stock apex helix let me know
Washers or a shimmed secondary is prevent coil bind. This can add a few mph to the top end.
It is important to shim the secondary when the primary has been cut for overdrive.
Blue_Blood
- Nov 3, 2015
- sarnia
How would I know if the primary has been cut ?
Blue_Blood
- Nov 3, 2015
- sarnia
Does anyone have the number off there stock apex helix ?
If the belt goes all the way to the top of the primary then you know it has been cut. Normally it gets about 3/4" from the topHow would I know if the primary has been cut ?
- 7K
