Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
If you look in the tech section you will see Yammi used two different part #'s for the same 51-43 helix, depending on the year. For reference, the stock 51-43 helix measures out to, and acts more like a 48-42. The washers will prevent coil bind like Steiner said, and may net you a couple miles an hour extra in absolute perfect conditions.
Blue_Blood
- Nov 3, 2015
- sarnia
- 2010 yamaha apex ltx gt
Ok yes this is what I've been noticing thanks a lot for the info !
HABS 1
- Oct 22, 2015
- corunna,ontario
not worth just shimming helix, leave alone or put complete clutch kit in
Why not shim. Stops the coil bind letting the secondary work more efficiently. Can't hurt can it??
HABS 1
- Oct 22, 2015
- corunna,ontario
never herd or experienced a " coil bind" problem, shimming just looks and sounds like a cheap backyard way to gain probably nothing
Well don't tell that to the guys that have built the fastest Yamaha in North America.never herd or experienced a " coil bind" problem, shimming just looks and sounds like a cheap backyard way to gain probably nothing
http://www.gforcedivision.com/#!ovdapex/cba1
HABS 1
- Oct 22, 2015
- corunna,ontario
ya coil bind on a cut primary were talking about the orignal post , everthing stock except washers behind helix , no good , especially when stud aint all the way throgh your lock nut when shimmed
Blue_Blood
- Nov 3, 2015
- sarnia
Ya Def don't want my secondary blowing apart it's going back the way it should be !
