Apex crankshaft bearing size?
quadsean1
Brighton, Michigan
Looking for some information on determining the correct bearing size for my apex crankshaft bearings . In the manual it say to take the numbers from the crankshaft and minus the numbers from the crankcase so the numbers on my crankshaft from left to right read 22232 and the numbers on the crankcase are read from left to right also like the manual says but the are upside down on my case but they read 44128. On the crank their is 5 bearings output side being 1 and mag side is 5. And on the case out put is 1 and mag is 5. The formula says to take the case number minus the crank number then minus 2 to get the bearing codes
-1 = violet
0 = white
1 = blue
2 = black
3 = brown
When I do the formula for my bearing this is what I come up with. Output side 1 = white. 2=violet. 3=violet. 4= -2 no bearing. 5 = 4 no bearing. Any help would be great thanks.
-1 = violet
0 = white
1 = blue
2 = black
3 = brown
did u look close at the bearings sometimes u can see the colours
yes but I figured it out months ago it was just a single 5 numbers stamped on the case that you go off of. But thanks
