mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
I would try to locate a dead cylinder, maybe use an infered thermometer. Like MrSled said, it sounds like its missing bad
1exciter
- Jan 13, 2014
It’s got the Gems controller o it and is grounded good . However the engine runs the same with Controller Un plugged also
1exciter
- Jan 13, 2014
I’ve checked all plugs and none were wet but I do agree it sounds to me like it’s onky running on 3 cylindersI would try to locate a dead cylinder, maybe use an infered thermometer. Like MrSled said, it sounds like its missing bad
I can’t keep it running long enough to heat up the cylinders
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700
- Niles, Oh
BTW your pressure sensor should be referenced to intake pressure somehow.
1exciter
- Jan 13, 2014
Well we’ve got her figured out
The entire time it was a miss adjusted throttle cable . It was not adjusted to sit on the throttle stop so it was throwing the sensor and everything out of wack . We got her adjusted and she runs like a monster ! My son got to make a couple test hits on the grass and says it’s a handful!
Thank yiu to everyone that helped and gave us advice ! What a great forum!
Awesome!! Thank you for giving us a report back. Great info!!
