JERSEYJOE
Could someone point me to the link for step by step removal and install of the GT skid?
Judder
Not sure is there is a how to, but there is just 4 bolts you need to remove to take off the skid. I took mine out the other day to fix the shock wire and it took less then 5 mins.
arcticace
take the rear bolt out of the tranfer rod then remove the 4 bolts holding the skid in. removing the bolt from the tranfer rod let the suspension collapse and makes removal and installation easier to line up the holes and not crossthread the bolts.
Try Here (second one down)
http://www.totallyamaha.com/snowmobiles ... NSION.html
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
Yep, that is key.....arcticace said:take the rear bolt out of the tranfer rod then remove the 4 bolts holding the skid in. removing the bolt from the tranfer rod let the suspension collapse and makes removal and installation easier to line up the holes and not crossthread the bolts.
