Apex in side by side, rev limiter issue?
Tymadd
calgary
Canada
Apex/Tomcar
I recently install my apex engine into a side by side.
The issue I'm having is the engine appears to be hitting rev limiter but the gauge is only reading 8000 rpm. Not sure if my issue is clutching or if it is an electronic issue. The only code the unit is flagging is code 42 as the apex speed sensor is not reading any speed, as I'm using the stock side by side display.
In the error code for #42 it states it is the speed sensor and is flagged as Able Able.
Any advice would be greatly appreciated.
