sledfvr
Shut the sled off and went to restart and its dead...no gauges, fuel pump, or clicking. I've swapped ecu, ignition, starter relay, swapped solenoids, checked fuse blocks, all fuses. I have no power at the red/white wire that plugs into the starter relay. If I run a wire from the battery to the red/white wire it starts up fine. Any ideas where that wire may have lost power at?
