scotstr
- Mar 23, 2006
- South of Buffalo, NY
- `07 RS Rage, `04 RX1 LE-Dead
I need a motor for my '04 RX1. Spun crank bearing in original motor, mechanic says find another motor. I was just wondering if I found an Apex motor short block, would my RX1 carb rack and stator bolt onto it ? Are the motor mounts the same ? I was thinking it might be easier to find a used Apex motor than an RX1 motor, since they made them for more model years. Any Ideas ?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
scotstr said:I need a motor for my '04 RX1. Spun crank bearing in original motor, mechanic says find another motor. I was just wondering if I found an Apex motor short block, would my RX1 carb rack and stator bolt onto it ? Are the motor mounts the same ? I was thinking it might be easier to find a used Apex motor than an RX1 motor, since they made them for more model years. Any Ideas ?
To answer your question yes an apex motor will fit right in. The heads are different. You will spend more time and money trying to make am apex motor work. I have (1) rx motor in stock. Send me a pm if interested. I also do service work and could install.
