ppwhite
Well I was able to ride the roads tonight ,holland ny just getting hit with a ton of snow. I fired my 06 apex gt up hit the roads for about 8 miles stop at buddies house for 45 mintues . Went to leave no fuel pump . Had to load it on to a truck and bring it home .Wheni got home i got on ty 4 storke and found the post about hitting fuel pump relay, of course it worked. I see the new parts# Is this corrected relay so this dont happen or just a spare in case it does happen again. Thanks you anesome web site this is. Paul
SERPAGS
Do the 07s have the same problems with the relay, or has it been corrected?
DYNAREX
07 have an updated relay
part# is different
part# is different
SERPAGS
Excellent !!! One less thing to worry about. I was ready to get an extra relay before my trip.
Sno Cat
What's the p/n for the new relay?
favarcat
Sno Cat said:What's the p/n for the new relay?
#8FP-81950-01-00
rkowal
I have the 07 Attak and it has acted up as well, but only 1 time.
favarcat
I read where the Rev sdi's have been doing the same thing when cold. Guys were bringing the relays inside at night while staying up in MtValin. 2 nights ago it was a low of -45F and -20F at noon.(temp, not windchill) It seems the frost is making the contacts not work. Some of there's would also work when tapped on. If the 07's are doing it, it doesn't seem the new relay is the answer, but it's good to have a spare with you.
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
again...don't panic if you don't have a spare...3 of those relays are the same part number....
Kevin Garceau
Would be nice if someone had some pics and step by step on this.
I realize its not difficult. But with the temps we have here I really havent had the opportunity to crawl around my sled yet. Its just too friggen cold. However would be nice to have a reference in the next few weeks if something were to happen.
I will buy the first beer to whomever posts the pics and step by step
87gtNOS
- Nov 30, 2005
- Toronto
all you need is a star screwdriver (phillips) and remove the 2 screws by your left foot and pull the plastic out of the way, stuff your hands in there and start pulling the relays...one of the two closest to the tunnel are the fuel pump...some sleds it's one, some it's the other...
Kevin Garceau
do you need to get under the hood or can you get to it from teh footwell?
87gtNOS
- Nov 30, 2005
- Toronto
Kevin Garceau said:do you need to get under the hood or can you get to it from teh footwell?
take ya 2 seconds to yank the side panel....
Kevin Garceau
Now Im starting to get a mental picture of where its at...thanks.
I keep hearing its here or there, but just behind the footwell. I figured it had to go in from the side panel but wasnt quite sure.
