VMX
- Nov 9, 2003
- Ma.
- 2006 GT ,2007 RTX, 2011se
I just bought a 2011 apex se used from a local dealer and after getting it home and running it some it developed an oil leak they took it to the shop and found it was leaking from the bottom engine cover gasket has anyone else ever heard of this before
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
The most common, is from the amount of oil that drops into the belly pan when the oil filter is changed. If the dealer did an oil change, that would be my guess.
If they have pinpointed it to a spot on the engine, then that would be rare. Based on it's location, and the amount that always spills, I would still blame a filter change. The other is the drain on the bottom of the crankcase has a crush washer on it. If they used a kit, they may have added a washer without removing the first. Two washers will cause a leak many times.
Good luck, report back what you find.
VMX
- Nov 9, 2003
- Ma.
VMX
- Nov 9, 2003
- Ma.
They tried to tell me it was oil that was leaked down but it happened while it was running and about a quart of oil on my garage floor after they got it back in the shop and looked at it some more they found it was leaking from the lower pan on the engine at the gasket I had never heard of it before that's why I posted it here
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
The lower belly pan of the sled, or the "lower pan" of the engine? I didn't realize the engine separated that way. Good luck.
VMX
- Nov 9, 2003
- Ma.
Yes there is a plate on the bottom of the motor it actually the sumpThe lower belly pan of the sled, or the "lower pan" of the engine? I didn't realize the engine separated that way. Good luck.
Winderallday!
- Dec 4, 2007
- SW, Ontario
- 2018 Sidewinder DX
That is strange, never heard of that kind of failure. Rare to have the need to horse around with the bottom end, unless motor was out for some reason and didnt get put together properly.
Hope they fixed it properly and didnt bandaid it. Good luck and enjoy your Ape!
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
that just don't happen did the dealer do the oil change did they crack the case with an impact gun? I have never heard of this failer with out hitting something hard or poor servicing.
VMX
- Nov 9, 2003
- Ma.
there was no sign of any impact underneath they said it was coming out at the gasketthat just don't happen did the dealer do the oil change did they crack the case with an impact gun? I have never heard of this failer with out hitting something hard or poor servicing.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
well at least it is just a gasket then.there was no sign of any impact underneath they said it was coming out at the gasket
