yamadooski
Any hints on changing the plugs on our Apex's? I'm going to tackle this and the bulb replacement over the weekend and would appreciate any suggestions on how to do it without problems.
xcsp
Plug change-Already?
Go here for more info on how to get to them:
http://www.ty4stroke.com/viewtopic.php?t=17722
Why are you changing them already-got alot of miles on the sled? Shouldn't have any problem running for 6-8k miles.
yamadooski
Plug Change
I've bought the CR10ek plugs and want to install them this weekend. It doesn't really need a change but heard a lot of good things about the colder plugs. Will be doing the same in the Vector and Rage but it's a whole lot easier on those sleds.
Thanks for the reply and information.
its not that bad yamadoo just when you take the bolt off the coils twist and pull up at the same time and you have to take off your resevior coolant tank to get to one of the plugs make sure you have long extensions to reach the plug's what i did was use the wrench you got from yamaha to remove the plugs then i got a socket that fit over the smaller end of the plug wrench and added 2 extensions and bam not a prob i used 1/4 inch socket wrench and deepwell socket it's well worth it good luck
