bougon_Apex
- Jan 29, 2024
- La Sarre, Qc
- 2008 Yamaha Apex LTX GT - 40th Anniversary
Hi boys I’m about to put my shock in my rear skid but the rear mount eye collar thats in there seems to be really loose. Don’t know of its normal or not
On yamaha they seem to list only the collar that goes inside the eye and bothing else So I don’t know whats it holding it in place in the eye mount.
Ohlins shock
Ohlins shock
If I remember right there should be a collar insert with roller bearings & then you slide your steel collar into that. Look inside of the rear collar tyo see if any of the bearing are missing.Hi boys I’m about to put my shock in my rear skid but the rear mount eye collar thats in there seems to be really loose. Don’t know of its normal or not
Ohlins shock
RobX-1
- Coldwater, OH
bougon_Apex
- Jan 29, 2024
- La Sarre, Qc
Yes that I was thinking also because I changed them for the transfer rod before. Does anyone no if the transfer rod bearing will fit or they specific to the ohlins shock?Yes, the roller bearing that @TrueBlue mentions is similar to what is used in the control rod (pictured below). At least with the control rod, they list the bearing but not for the Ohlins shock:
RobX-1
- Coldwater, OH
@cannondale27 might now as he is the one who service's my Ohlins.
Ohlins uses a spherical bearing with two o rings in there. Can supply part numbers.
bougon_Apex
- Jan 29, 2024
- La Sarre, Qc
Oh sweet could you sent me those?Ohlins uses a spherical bearing with two o rings in there. Can supply part numbers.
00536-12 for the bearing. 00338-25 for the O-ring x 2. If no TY vendors can supply, I can, might even have some good condition used pieces.
