I want to add 2 inches to the hight of the bars, it looks like a 6 inch now,do I get an 8 inch? or a two inch and add it to the six?,also an 8 inch must have the correct shape to fit the lower ring,thanks.
Check out ROX or Lake Effect Risers 2" of staight or pivot to add to your existing riser. They both make great stuff.
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
We (Muffin Works) have a riser design that has an adapter block that fits the chrome trim ring. Our adapter block and 6" riser ends up with about 8.5" of total rise when measured from the top of the steering post to the center of the bar. All risers come standard with a polished finish. Our new riser design also has a 7-position positive locking system. Once you have the pivot where you want it, the design locks down and absolutely will not move on you.
ross13
- Oct 4, 2010
bar risers
i wanna put 2-3 inch risers on my 08 apex rtx....nothing crazy just a little extra so i can stand up easier. any good sites to find them on. also with 2 or 3 inch extensions do you have to add cable extensions?
Blue Oval
Re: bar risers
On my 07 I added a 2" Rox riser but I had to go with the apex MTN. cable to be safe, the stock cable was just too tight and was an issue when the bars were turned. installation was easier with two people for the cable FYI.ross13 said:i wanna put 2-3 inch risers on my 08 apex rtx....nothing crazy just a little extra so i can stand up easier. any good sites to find them on. also with 2 or 3 inch extensions do you have to add cable extensions?
Snowmobileaddict
sxr1000 said:it looks like a 6 inch now,do I get an 8 inch? or a two inch and add it to the six?,also an 8 inch must have the correct shape to fit the lower ring,thanks.
i just added an Apex mountain riser for 1.5" increase and a stock look. Port Yamaha $70
jneilsonjr
that is what I did, Just added the Apex MTX OEM riser, you have to buy longer bolts though. It looks OEM
Lake Effect 2 1/2" pivet riser.Has holes tapped for Ram Mount.
Just had to move the cable from the trigger under the bar.Great product & service.
www.lakeffectsnow.com
Superman
We also do a 3" pivot adapter that you can put a 5" bar riser for a 2" total rise over stock. The 2.5" pivot riser like tcona-AGT
has pictured above is our easiest way to raise your bars.
The middle 2 pictures in my signiture below show what each look like.
troyhatt
powermadd has a 2 inch pivot riser, works great about 50 bucks..
- 7K
