Apex/ Rx1 secondary helix on Rs Vector
Port Perry, Ontario
Canada
2010 Vector ltx GT
2010 MXZ X 1200
LOCATION
Port Perry
I have been told that installing a Apex helix on the rs vector is a value added upgrade. Apparently it will lower the cruise RPM and accelerate faster. I have not really ridden the sled, only around my property for thirty minutes or so. Plan to try it out before I make this change but it does seem like something that I would be interested in .
I did a search but can't find this specific modification.
Has anyone performed this and does it work well?
Sounds like it would be a good upgrade, I would definitely look into this setup more
I'm surprised that nobody has performed this modification.
This is what it apparently will do.
Basically it will lower your cruise RPM, and accelerate faster by loading the motor harder/faster. Those triples have tons of torque, and were known to over rev while accelerating. The smaller primary rollers we talked about will also help with this, along with lower engagement RPM as well.
