newrx1guy
Is it a big job to put apex or nytro seat on an rx1? Thinking about seat and handle bar up grade. Anybody have any pics of theres and was it worth the money.Alot cheaper than new sled lol Thanks
Eggman
Alot have done this and it sounds like it is not that bad. I think the hardest part is trimming up the gas tank cover to fit the new seat. Look under FAQ in 4-stroke forum, Kinger has a good post on this.
sleddheadd
i have done it. put on an apex seat it is not a big deal, kinger has done it and quite a few others . check out the 4-stroke garage and browse around there. you will find pics. and info. about the changes!
http://www.ty4stroke.com/viewtopic.php?t=45203
hope this helps a little
I have a Nytro seat on my 05 RX1. Not difficult. This post should get you started.
http://www.ty4stroke.com/viewtopic.php? ... ce&start=0
wallisan
Seat
Pretty simple, lots of good tips around. We used a sharp knife totrim the cover.
kinger
DoktorC
This is hands down the best mod for the RX...Totally transforms the sled.
newrx1guy
Thanks for the posts. All I need now is to find a seat. Is the nytro seat and apex seat the same? I love the idea of having a place to put things again,like a tow rope for the boys lol... What is the tallest riser you can put before you have to longer cables??? Thanks Again
kinger
Apex Gt seat is more soft and not as tall as the nytro seat, also it has a different wiring harness so you have to swap it out like I showed in the FAQ. The nytro seat is taller and firmer and the harness plugs right in assuming your getting that with the seat.
Tallest risor is said to be 2" however I was not comfortable with the stretch at full turn on the 2" isovibe risor so I bought longer brake line, throttle cable from a 05 mountain RX1 and Choke from the same sled. The e-brake gets awful tight but I may end up removing that in favor of the lever that uses the regular brake, not sure yet.
And the make sure you get one with a trunk!!!
Boomer
I've decided to do this mod to my RX-1. My only question now is how much of a riser did you guys use who did this. I'm 6'2" or so with the boots on and the worst thing with the stock set-up (even with 2" of additional foam in the seat) has been the transition to standing. Is 3" about right?
And if you use a jig saw dont hit the gas tank. I had to buy a new one!
The riser i have i think is 3 or 4"
Skydog
Skydog
Boomer
