Apex secondary question?
jds1000
Chautauqua NY
I took off my driven clutch today to clean up the grease behind it. I was very carefull to see where the washers went on the shaft and bolt. Well one of the washers fell and I think it came from behind the driven clutch. My question for you guys who have taken off your driven clutches is how many washers are behind it? I'm guessing there is one flat washer and one washer with a step in it. Thats the way I put it back together, am I right?
The step in the washer always goes against the brg.
2 washers behind the secondary. 1 thin flat and the thicker stepped washer. Stepped washer rides closest to the motor/drive shaft.
