ebockus
i have done a ton of searching but still have this stutter when i pan it. if i feed it to wot its ok for a second then will drop rpm and sounds like a rev limiter. its been deep snow so im only hitting 10,000 rpm. if i go from 1/8 throttle to wot its just stutters and hits 9000. like its dropping a cylinder. i changed my cr10ek plugs. it got better but is still there. i read about tors issues but it sounds like they have different symptoms. i tested my tps and i think the spec was 3.5-4.0 volts at wot and im like 3.4. the idle volts were in spec. thoughts? 2006 apex with 15000k
