I only cheked that the valve play wasent to big (valve shim on place because it worked fine before) The sled have now total of 800 km on it
The idle stumbles sometimes 1600 -1700 but when hitting the throttle works fine from 5000 rpm but on idle somtimes stop,feels rich stumbles a bit in the beginning maby co, when cold start starts on the 3 try when hot a little throttle helps
