Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700, 2023 Polaris Boost VR-129
- Niles, Oh
Hard to say but at least it would be 1 thing to cross off the list of possible issues.
Bicycle_Mafia
- Sep 15, 2013
- Jonesboro Arkansas
- Yamaha Apex RZR
Does it sound to you guys like the tors is taking over? I thought I bypassed it but I'm not sure I have. I connected the black and white bullet connector together. Is there something else I have to do to bypass it?
Macheater
- Feb 7, 2006
- Niles, Ohio
- Niles, Oh
Its more likely that the speed sensor circuit needs satisfied. If it was the tors you would have a trouble code flashing in your gauge cluster and you say it isn't. If it was the TORS, the ecu likely wouldn't allow the machine to accept any throttle, which is typically how it works. Work on getting an input from the speed sensor to the ecu and go from there. You wouldn't even have to make a permanent setup at this point. If you could just fool it temporarily to take the machine for a test ride to see how it responds. If it were me, I'd hook up the sensor, find a way to mount the gear to a cordless drill and find a passenger to work the "speed sensor" while you take it for a ride to "test" it. Or you could "engineer" a better approach. Either way all you are doing at this point is diagnosing the problem.
Bicycle_Mafia
- Sep 15, 2013
- Yamaha Apex RZR
10-4 guys! Buying a speed sensor now. Will post an update on what the results are in a couple of days when I get it in.
- 6K
- 6K
