Bigdog39
- Jan 28, 2013
- Grand Rapids, Mn.
- quietridemuffs.com
2006 Apex, fuel pump comes on, new battery this year, just a small click sound, yellow light comes on, does not turn over, 5 below, happened a week ago, Apex was in garage heated garage to investigate, Apex warm turned on key turned over normal and started. Seems it does not like the cold.
thoughts bad starter solenoid?
Dirty sticking brushes?
I will check battery connections, but I think they are tight.
Help
Help
suprfst
- Dec 4, 2004
- Tawas Michigan
- www.smcfabrication.com
Your starter may have a dead spot. Turn primary clutch backwards a tiny bit and retry it.
ranger1
If the starter has a dead spot, how is turning the prim clutch back going to do anything?suprfst said:Your starter may have a dead spot. Turn primary clutch backwards a tiny bit and retry it.
Bigdog39
- Jan 28, 2013
- Grand Rapids, Mn.
Bigdog39 said:2006 Apex, fuel pump comes on, new battery this year, just a small click sound, yellow light comes on, does not turn over, 5 below, happened a week ago, Apex was in garage heated garage to investigate, Apex warm turned on key turned over normal and started. Seems it does not like the cold.
Help
Starter Solenoid would not work when cold like below 0 F Took air box off solenoid clicked when turning key, but not turning over starter, check voltage from battery ground side to hot wire on starter, nothing when key turned on, nothing there. Put hair dryer on starter solenoid for a minute starter worked fine double checked power from ground on battery to hot wire on starter, plenty of power. ordered new starter solenoid. Lots of corossion on solenoid housing and plug in connection.
Bigdog39 said:Lots of corossion on solenoid housing and plug in connection.
Clean up the contacts on the plug. Then liberally apply dielectric grease into the connector. Fill it right up.
This will keep out the moisture and keep a good contact with the soleniod.
Bigdog39
- Jan 28, 2013
- Grand Rapids, Mn.
Good idea. I will do that when I install the new solenoid when it arrives in three days. There was a lot of corrosion on the connector plug to the solenoid which made it hard to separate from the defective solenoid.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Bigdog39 said:Good idea. I will do that when I install the new solenoid when it arrives in three days. There was a lot of corrosion on the connector plug to the solenoid which made it hard to separate from the defective solenoid.
I am glad that you found the problem. Welcome to TY! Please add your location to your profile.
CaptCaper
- Jan 1, 2007
- Northern N.H.
- 2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
- New Hampshire
I WD 40 all connections often. Learned this in my marine engines,switches,etc. on trucks and now snowmachines. Your electricial system and connectors will stay A1 with WD.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
CaptCaper said:I WD 40 all connections often. Learned this in my marine engines,switches,etc. on trucks and now snowmachines. Your electricial system and connectors will stay A1 with WD.
Do you spray down the blades on the connections too?
CaptCaper
- Jan 1, 2007
- Northern N.H.
- New Hampshire
yes evey were. WD creeps in well. Only thing is it don't last so frequent applications are needed.
Also it attracts dust but never had an issue on the trucks,plows I've had do to I keep spraying.
Also with are snow machines we don't pickup road dust,etc. so the connections stay clean for sure.
Do it on all sensors,grounds,switches,etc.
