mtaylor
- Jan 2, 2016
- Upstate NY
- 2011 Apex
Need some assistance. After replacing bad starter I’m re-installing everything and cannot figure out where the large black lead (coming off the negative cable) goes. Does this ground to frame? I took this machine apart about 3 months ago and old age hasn’t allowed me to remember how to reassemble! Thanks.
RobX-1
- Coldwater, OH
Are you referring to negative jumper wire that goes along with the positive jumper wire and are used to jump start the Apex?
mtaylor
- Jan 2, 2016
- Upstate NY
- 2011 Apex
No, there's another wire tied to the negative battery cable that goes somewhere. I think it may just ground to the frame or starter? I removed the starter to replace and this one sits beneath the battery compartment so I assume it came out with one of the starter bolts when I removed it but I'm not entirely sure. Thanks for the response!
RobX-1
- Coldwater, OH
Correct, the main lead of the negative wire gets secured to the frame via one of the starter bolts. I thought you were inquiring about the other lead off of it.
mtaylor
- Jan 2, 2016
- Upstate NY
- 2011 Apex
Great thank you for your reply! I still have a no start issue I'm running down. Going to test the starter relay next.
