ebockus
I put precision skis on my apex, what an amazing difference. I bought them for 180 used with carbides and they we the best investment so far. Maybe I'm jumping the gun here was only one ride but I did follow a apex with yam a skis and watched it push all over. I could steer inside, outside around this guy no prob. He had dual lies on which was the set up I ran and it worked ok. Anyway a little info on instal, one of the prcision ski bushing has to be flipped to the outside and u need a 1/4 inch thick piece of rubber about 2x3 inches to fill a void under the stock yam a rubbers. The aluminum saddle has a rectangular void under the spindle which should be filled. The yam a bolts are to long. They work but u need a half inch long bushing to take up the extra bolt. Like a big thick washer. I used bushing from my yama skis for now but will get shorter bolts from the ski don't dealership. I just hope it wasn't a one ride thing but so far I totally impressed.
kingtut
- Nov 1, 2013
- Traverse City, MI
- 2006 Apex
Have you tried taking these skis off trail? How wide are they? I'm looking into a different set of skis since my apex likes to bulldoze with the AD bovin expert x suspension in it. Glad you wont be getting beat to all hell after a good ride.
ebockus
Yes i had them off trail. seem fine. they are about the same width as apex ski. they still dart a little but the steering is amazing. Im usually described as an aggressive rider by friends lol just a fyi I'm pounding these skis
kingtut
- Nov 1, 2013
- Traverse City, MI
- 2006 Apex
I believe 6" skis are generally trail skis. Do you have a single carbide runner? At what length? You got a good deal in my opinion.
ebockus
Precision skis have two runners on each ski. on the outter edges. Google precision ski click on images at the top. i may try 1/4" shim on the keel see if it helps the bit of darting i experienced
cat hunter
I tried the Precision skies in 2003 on my RXI they worked better than stock but not good enough .Slapped on a set of aggressive Snow trackers and what a difference!!! For me this is all I ever use.
kingtut
- Nov 1, 2013
- Traverse City, MI
- 2006 Apex
I can't seem to find the website to precision skis. I heard this needed to be done on some of the C&A skis, my buddy had a pair on his phazer and it was really hard to turn. For the snowtrackers, can you put them onto aftermarket skis or are you boned with your stock skis.
MarkRTX
Do yourself a favor and pick up a set of ZX chasis ski rubbers and get rid of your Yammie ones. It will fit better and will make the install look factory. They are pretty cheap if I remember right at any local Ski Doo dealer.
