Jori K
- Dec 12, 2021
- Finland
- Other
- apex 2006 GT
That's not easy and economically reasonable task to do competitive 150 - 200hp 4-stroke engine for only snowmobile.I would think that Cat has its own 4 stroke in development. My guess is that Textron will have its own engines. The St Cloud engine plant is modern and capable.
Not impossible but I will be very surprised if Cat/Textron bring to market something like BRP 900R turbo or Yamaha 998...or even some similar than old 1056 Suzuki
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
Maybe they make something similar to the 1100 Suzuki twin and use it elsewhere. That engine was an anvil of reliable power and I believe was assembled by cat. I still have my 2014 9000 with a 240 HP tune. That motor is a beast and gets 14/15 MPG. I think a twin would probably fit better in the new chassis. We will see what cat does.That's not easy and economically reasonable task to do competitive big HP 4-stroke for only snowmobile.
Not impossible but I will be very surprised if Cat/Textron bring to market something like brp 900R turbo or 998...
stgdz
- Mar 27, 2021
- Buffalo MN
They won'tThat's not easy and economically reasonable task to do competitive 150 - 200hp 4-stroke engine for only snowmobile.
Based on the catalyst it's going to be a twin and will likely be there universal motor to in sxs and atvs.
And that means a 900 ish sized twin. The engine cc's plus turbo must be less than 1000cc's for it to be considered a sxs per the rov in most state legislatures. And if you want the most power you go with the most cylinders. It's one reason why brp uses the 900 in a lot of things.
Economies of scale and such
Unless cat builds a triple and then that makes no sense as to why they gave Yamaha the middle finger because cats triple will perform like the doo triple.
Jori K
- Dec 12, 2021
- Finland
- Other
- apex 2006 GT
They won't
Ok, they gonna lose marketshare with 4-stroke if they don't offer something like BRP 900r turbo or 998 SW engine..
They already give up some reason with Suzuki turbo twin, if they come back with something similar it's not will be very interesting if not lightweight and at least 200hp...
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
With Textron owning Weber there are probably several choices available for Cat to use and fit into the Catalyst chassis. Cat can always make the bulkhead a little wider to accommodate different engines like Ski Doo does and use the same tunnel/suspension system for all. The real question will be if the golden age of 200HP sleds from the factory is over (for now). When Cat ditched the triple Tcat after 2002, I rode my old Tcat for a long time. Looks like my 2022 EPS Tcat will be with me for a long time.
stgdz
- Mar 27, 2021
- Buffalo MN
Well can am just dropped a 240hp 999 in their new massive proportions sxs.
Wonder if it will fit into a g5.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
It's not a belt-drive motor... but maybe could still work. It has a 7-speed sequential transmission.Well can am just dropped a 240hp 999 in their new massive proportions sxs.
stgdz
- Mar 27, 2021
- Buffalo MN
Yxz has flippy paddles and that motor is essentially the same as our beloved 998.It's not a belt-drive motor... but maybe could still work. It has a 7-speed sequential transmission.
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
New 2025 Arctic Cat ZR 9000 RR Review | Snowmobiles USA
With the debut of the 2025 Arctic Cat ZR 9000 RR, the company has once again set a new standard in the snowmobile industry.
snowmobilesusa.com
Appears the 998 ain’t dead yet.
stgdz
- Mar 27, 2021
- Buffalo MN
After 2025 it is.![]()
With the debut of the 2025 Arctic Cat ZR 9000 RR, the company has once again set a new standard in the snowmobile industry.snowmobilesusa.com
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Does that article claim the 998 is in the Catalyst chassis for 2025?
Am I reading that correctly?
Cant be accurate.
That site doesn't even look real????
Cant be accurate.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
The cutaway pic even shows the 2-stroke motor in it.Does that article clam the 998 is in the Catalyst chassis for 2025?
Cant be accurate.
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
DId you see their photo of the 2025 renegade? Fake news!Does that article clam the 998 is in the Catalyst chassis for 2025?
Cant be accurate.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
2025 Sidewinder LTX on the site.. yeah.. right.. Nothing says AI generated like a completely non-functional track, spare bits of metal in the springs, and a completely un-realistc front suspension.
ishpeming fan
- Feb 5, 2017
- Bristol WI.
- 2019 ZR RR 8000
The only way that viper walks an 850 is if it has a turbo and a host of other goodies! Stock Viper is not in the same zip code as a 850The 850 is a pooch. My 850 Rave RE gets walked by my daughter on her 2016 Viper. Buddy has an XRS 850 and it’s aloooow also.
