Hi there!
As the topic sais, are there any common problems with the Nytro?
Its always good to be alittle prepared and know what the problem could be if you are in the middle of nowhere.
I think Dimebag and ntm can say a few words on this subject cause I know that they are high milage riders and have run into som smaller issues out in the field.
One of the things dimebag told me about was:
- Frozen starter relay (no start)
- Blown main fuse due to grip-warmer short circuit in the handlebar (sled dies)
- Exhaust donuts (wear out fast causing exhaust leak right under the gas tank) - install copper donuts instead
I `ve decided to print the fault codes and have them laminated and keep them in the sled incase I get a code.
Maybe we could discuss this in this thread and then make a new sticky thread about this.
Or ?
Or ?
