yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Great choice!!! You are in good hands (best around!)imoonce I decide which route to go I’ll buy all my stuff from Tom, good guy , knows how to make em go
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Things to think about.....
When going above @240 HP you WILL need a BOV and a MAP sensor for proper operation--$$
When going above 240 hp its time to start to think about changing the stock primary, TAPP, RX-1, CV-Tech etc, whatever you choose--$$$
When going above 240hp you start to stress other driveline parts, chains stretch quicker, tracks stretch quicker, more traction is needed, ETC.--$$$
In my opinion the stock secondary seems to work as well as an aftermarket one so you can save some there but will need a different spring and probably rollers. A helix also if you choose but the stock one works.
Once you get a taste of more boost, you will want MORE and MORE boost!!! It is addicting for sure.---$$$$$
All this being said, I love riding my 270ss spool tune and all the money I spent on the other parts is just the price of admission!!! I rarely ever use 240 hp and have never tried the 225.
Joshua
- Apr 14, 2010
- Newfoundland
- 2018 Yamaha Sidewinder BTX LE 50TH
If someone did go and buy a tune from any of the companies mentioned, how would one know if they got the right tune? Does it display the tune on the cluster on start up?
Good arguments here on both sides, single or bundle.
I did quite a few 235hp(ecotrail) for people this year as I simply don't trust some of them to use good judgement if they have a 265HP tune and can only get 87 octane fuel.
Turboflash
- Mar 18, 2019
- Southern MN
W PEFI, my invoice showed the tune level and the license # for my tune, traceable back to their master file. I suppose in this day and age, anyone can cheat but what's their incentive to do that? If they sold you "270" and you get beat by a "225" it makes them look really bad. I think it comes down to doing business with firms with proven reputations over time.
KillerBee
- Jan 1, 2010
- Waukesha WI
- 2018 Sidewinder LTX LE 50th
My hurricane multi flash shows what tune you are running in the upper left corner of your gauge when you start up or switch tunes (and it stays displayed). One click operation with the cluster flash. Just push the upper left button on your cluster.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
For a single tune you would need to plug in a flasher to know what tune is in the machineIf someone did go and buy a tune from any of the companies mentioned, how would one know if they got the right tune? Does it display the tune on the cluster on start up?
If you have a bundle then the hp is displayed on the gauge.
You get a boost pressure display on the gauge cluster with a single or bundle so you could figure out what hp you have by reading the max boost pressure at wot
SledFreak
- Feb 7, 2005
- Ontario. Canada
This would be the tune, I think I would pick, which I think is TD Max 16, 270hp, single tune. Also it sounds like a different BOV and for sure Clutching would also be required. At what point do you need to change the stock muffler or mod the stock muffler?exactly, some guys with multimap clutch for the biggest tune and when they go to smaller tune they are now under revving. I run maxspool 16 and have my clutching dialed in perfectly for it. It runs consistently all the time. If you go single tune, think long and hard if your gonna want more power down the road. I ran ecotrail stock muffler at first and a month later I upgraded to maxspool 16. Wish I would of just went max 16 to begin with. The beauty of all the tuners mentioned above is any of these pump gas tunes are unbelievably docile until provoked. I can ride all afternoon with my 2 up seat attached and my 8 year old on the back enjoying scenery and later that day carry the skis in the air till I decide to put them down. Point is, dont feel like a larger tune is harder to ride or you wont ever need it. They only come alive when asked.
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
- 2018 Sidewinder xtx
16 viper xtx se SOLD
08 nytro rtx SOLD
- Kirkland Lake
TD max 16 is your last stop with stock muffler. Should have map sensor bov and clutching cai is an option also.This would be the tune, I think I would pick, which I think is TD Max 16, 270hp, single tune. Also it sounds like a different BOV and for sure Clutching would also be required. At what point do you need to change the stock muffler or mod the stock muffler?
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
The max 16 tune is maximized when used with better blow off valve and 3 bar map sensor, runs 17.5-17.8psi. Its turbo dynamics most popular tune as its powerful enough for most people and doesnt require a different muffler. Anything more than that available currently requires high flow muffler.This would be the tune, I think I would pick, which I think is TD Max 16, 270hp, single tune. Also it sounds like a different BOV and for sure Clutching would also be required. At what point do you need to change the stock muffler or mod the stock muffler?
Joshua
- Apr 14, 2010
- Newfoundland
I'm planning on getting the 270HP SM SS before next season. It would be nice to see exactly that (270HP SM SS) in my cluster like the multi flash bundle
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Only way you'll see the tune in the cluster is if you buy the cluster flash .
STAIN
- Feb 29, 2004
- Vermont
- Vermont
My Hurricane multi-tune displays the tune HP in the hour meter upon start. After a couple of seconds it goes back to being a boost gauge. It displays hours when key is on/engine off.
SledFreak
- Feb 7, 2005
- Ontario. Canada
So Does a muffler actually do anything to the 270HP? By adding a freer flowing muffler, does it give me anything more over the 270HP utilizing the same tune?The max 16 tune is maximized when used with better blow off valve and 3 bar map sensor, runs 17.5-17.8psi. Its turbo dynamics most popular tune as its powerful enough for most people and doesnt require a different muffler. Anything more than that available currently requires high flow muffler.
You need to run a stock muffler with a "stock muffler" flash and if you install a performance muffler you need to have a "performance muffler" flash.
