Batmobile
- Nov 2, 2005
I just ordered a clucth kit from you guys stage 2
what would be the best belt for my GT.
Thank You!
Thank You!
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Stock belt is the only belt we recommend. Before you do much riding take the belt off and wash it in warm soapy dish water, then rinse it off and let it dry.
daveh
- Apr 29, 2005
Allen
Are you recommending we do this with any new sled's belt?
Dave
Dave
- Apr 17, 2003
- Menno, SD
- Menno, SD
Dave, I do this anytime I have a new belt.
MR.HAPPY
- Sep 30, 2003
- GREAT NORTH OF... ILLINOIS?
- YAMAHA
Have you done enough real tests to have a idea of how many sled lengths your Stage 4 kit will give a person?
600 ft.? -1000 ft.? -1/2 mile? -mile?
THANKS ALLEN!
BR
THANKS ALLEN!
BR
Batmobile
- Nov 2, 2005
Dave one last quest. do you think I should
reduce the gears on the GT"
Thank You
Thank You
Mrplow
ya thanks dave- is this foe better perf. or life expec.
daveh
- Apr 29, 2005
Thanks Allen.
I had heard that taking a bit of extra fine sandpaper and lightly sanding the belt edge was another method. Is it that we are trying to remove some greasy or waxy protective coating?
Dave
Dave
yes dave that is exactly what u are doing,i do it with all my belts,always have ![Div20 ;)! ;)!](/styles/default/xenforo/smilies/div20.gif)
- Apr 17, 2003
- Menno, SD
- Menno, SD
COLDONE said:Have you done enough real tests to have a idea of how many sled lengths your Stage 4 kit will give a person?
THANKS ALLEN!
BR
BR, check this post in my preferred vendor area!
http://www.ty4stroke.com/viewtopic.php?t=17657
daveh said:Thanks Allen.
Dave
Dave, it removes the greasy/waxy substance that is on the belt and just allows quicker break-in of the belt. Lightly scuffing it with fine sandpaper, a stainless steel brush, red scotch brite pad, etc works well also. Just be sure to wash it in warm soapy water.
daveh
- Apr 29, 2005
Just a quick question, what do the arrows on the belt refer to (if anything).
Should the belt go back on with the arrows pointing to the primary or seat or is it insignificant. Just pulled mine off to wash and scuff and noticed the arrows after.
BlueBlood
Arrow points to the primary ![Div20 ;)! ;)!](/styles/default/xenforo/smilies/div20.gif)
daveh
- Apr 29, 2005
One final question, I got the belt off (took a few trys to get the secondary
sheave to move far enough back) but the sheave seems to rotate very hard the last inch or so which is making it a bitch to get the belt back on. I am so afraid of breaking something that I don't want to lean against any piece of the machine like the bracket to the right of the secondary etc. Any trick here or am I simply not turning hard enough for long enough. I don't recall my Polaris's being this hard.
