attak air box
I did my first oil change on my attak on Friday. It wen fairly smooth. What too k the longest was gettin my airbox back on so that the boots fit properly. Has anyone else had this problem? Any pointers?
iorn range attak...........A trick I used to get the boots on to slide on easy was to put a drop of oil on the inside of the rubber boots and wipe the oil around with your finger. Aside from making the boots slide on easer, the oil keeps the boots from sticking to the throttle bodies.
take out the air box cover,take off the tabs at the front with a grinder. there not needed because of the clips.. no need to take off winshield or any thing other than the front hood
