So I have a plain Attak and last year some how the remote adjustment cable for the schock got broke, I got around to fixing it this year and put the new adjustment cable on and it is locked up tight! the adjuster turns fine but the shock wont budge, Anyone else had this problem? Do I need a new shock od do I just live with it?
copo427ss
there is a sequence to matching up the cable to the shock. i would pull your shock and heve it checked out. while its out have it revalved.
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
Regarding breaking the cable, you are not the only person. Pretty much anyone that has built up ice on the cable has broken it. I've replaced mine about four times now.
I think the cable knob turns the oposite direction of the end of the cable so you need to set the shock foull counterclockwise and the knob full clockwise. Just un hook it and turn it while watching the cable end.
Yeah but I think my problem is that the shock part of it is that it wont turn at all in either direction
olsmann said:Yeah but I think my problem is that the shock part of it is that it wont turn at all in either direction
OOOOPS.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Do u mean that the end of the cable is not turning or that the valve in the shock will not turn?
