True Blue
What is a good pressure to run in Fox shock on the front
end to start with @ 160lbs stock setup. 2006 Attak
TB
TB
WhadoIknow!
- Dec 19, 2004
With the skis off the ground the spec is 70 psi. Run 55 psi for lower cg / flatter cornering. Max allowable is 150. It's all in the owner's manual that should have been supplied when you bought it.
Never check the pressure with weight on the skis!
Here is a page from the Tuning Manual for reference.
Part # LIT-SUSPN-TN-07 Suspension Tuning Manual.
Have fun!
Have fun!
Bodacious
I started out at 70lbs, but have dropped to 55. Never bottoms at all, and the ride seems even plusher. IMO this is by far the best money that I've spent on any high dollar accessory in years. These things work!!
newfieattak
true blue did you get trade in your phazer mountain.
Yea the air shocks are UNREAL!!!
BlueBlood
Have mine set 50-55psi, works great. Read somewhere the 13mm bar and 50psi is very nice.
tsiceman
i'm running 30lb's, no ill effects just better handling(tons better handling than where i started @ 60lb). I did ? fox, they said run as low as you want (within reason). I might try 25 lb yet
True Blue
Phazer is traded and i went with a Venture RS for two up
riding. Kept the Attak of course.
TB
TB
newfieattak
RIGHT ON , THE 2 INCH AND MOUNTAIN SKIS ARE
CRAZY , HOOKS UP CRAZY
