heath@mpi
- Aug 20, 2008
It has come to our attn that Low elevation low boost supercharger kits in the canadaian area are running lean during cruise.
I beleive it is a fuel quality issue we beleive the amount of ethenol in the fuel is more then a tollerable level.
We have not had this issue in the last 2 years of the nytro only in the last month
Ethenol requires significantly more fuel and lower afr numbers then gasoline.
We have designed a new program for your GEMS controller to help richen this up.
PLEASE CONTACT ..MOUNTAIN PERFORMANCE.. TO SEND IN YOUR FUEL CONTROLLER FOR A REPROGRAM
ALL LOW ELEVATION CUSTOMERS WITH LOW BOOST
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Nytro only?
Nitrousman1
So if I ride Michigan and occasionally Ontario I should send mine in? I'm running 9lbs of boost.
Nitrousman1
heath@mpi said:do u run pump gas
Yes that's all I run.
heath@mpi
- Aug 20, 2008
I would recomend it just to be safe
Nitrousman1
What's the expected turn around if I send it in by next Monday?
heath@mpi
- Aug 20, 2008
it would go out the same day we receive it.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
what about 8 lbs in Mich.
- 9K
