radianguy
- Jan 1, 2007
Hey guys, I'm getting ready to install an auto tune on my nytro to go with my PCV(still need to download a map), my question is, in the instructions it says not to install where it would be subject to wet conditions, do I need to make some sort of block off plate to protect the sensor?
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
What exhaust do you have? In the hindle it was in front of the muffler about 3-4" and didn't need a guard for the sensor. Did need to mod the muffler shield so the o2 sensor can go through it.
radianguy
- Jan 1, 2007
Thanks!
Yeah I have the hindle exhaust, I have it apart to install the sensor, need to modify the cover like you said but I was just concerned about snow on the sensor. It will be ok there? I'd hate to have to tear it apart again to replace the sensor or make a plate. Maybe I'll make a plate anyway! Just looking for advice! Thanks again
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Your all set up then, I ran all last season with zero problems. Won't worry about the plate
radianguy
- Jan 1, 2007
Awesome! Thanks!
Did you leave the autotune installed after you had the map where you wanted it?
