Yes I would like to know also.
Yup, understand it can't act like a wideband sensor but still not understanding the need to defeat it. Maybe Dave from Hurricane will see this and explain his thoughts for leaving it in?
Hmm I wouldn't mind hearing from either hurricane or ulmer on this. But its sounds like it will be in my best interest to grab the autotune just to keep things safe
Hurricane actually uses a PCV for a nytro, the Viper one disables the stock o2 adjustment, theory is it won't try and compensate for the adjustments you're making with the PCV. The target A/F for the stock map is probably leaner then you'd want with your tune. Hurricane's map works very well with his set up so I wouldn't worry about it either way.
I was in McBride British Columbia last April riding in the mountains while tuning the Hurricane Viper turbo kits.The trick was to make a map that worked as well at low elevation as it worked at 8500ft.One of the tools that I learned to use was the stock Viper 02 sensor.I would start the ride on the trail and in about 5 mins I could see on the wide band gauge the stock ECU correcting the tune .This is an example of why I prefer the Nytro PCV on the Viper.I like to keep the stock 02 working at moderate throttle to insure a perfect tune all the time
Cant those of us with Viper PCV just hook the stock O2 back up? Should do same thing as long as AutoTune is off. Thanks for the infoI was in McBride British Columbia last April riding in the mountains while tuning the Hurricane Viper turbo kits.The trick was to make a map that worked as well at low elevation as it worked at 8500ft.One of the tools that I learned to use was the stock Viper 02 sensor.I would start the ride on the trail and in about 5 mins I could see on the wide band gauge the stock ECU correcting the tune .This is an example of why I prefer the Nytro PCV on the Viper.I like to keep the stock 02 working at moderate throttle to insure a perfect tune all the time
I installed my pcv this fall pre programed by ulmer. It didnt come with the O2 optimizer on the parts list. I left the stock O2 installed and plugged in. Should I disconnect the O2, plug the bung, and install the dummy resistor on the end of the factory O2 wire? Non turbo sled.
