Auto tune?
langow
West Bend, WI
Looking for some help with adding the auto tune module to my PCV. Does the O2 sensor for the auto tune just replace the stock O2 sensor? Or do I need to add another bung for it?
you will need to add another bung and it will be 18 mm i believe. the stock 02 is 13mm
You also have to turn the Auto Tune on inside the PCV in the setting. Power Commander Tools , I think its in configuration... the check box needs to be checked.
