newrx1guy
I installed a autometer temp gauge in my 2003 rx1. What temp should it be runnin. It runs between 150-170. I friend of mine did the same and his runs 110-120 degrees. Thanks for any input
150 to 190 in good snow conditions, the temp light comes on at 220
NY_Nytro
My warrior typical ran 165-180 under normal conditions. I believe 210 is when the overheat light comes on.
110-120 is way low, must be a bad gauge ot sensor
newrx1guy
Thats what I thought. 120 degrees seemed way to low
thisbudd4u
- Mar 8, 2008
Hey I just installed the Phantom water gauge to on my 03 RX1 this weekend! I'm running 160 on average, did go up to 180! Looks sharpe!
Ny_Nytro is right, light comes on at 210
RaWarrior
I put a Sunpro mechanical (capillary tube) gauge on mine, but otherwise followed the guide in the "technical" section on this site. On a groomed trail it runs between 150-160, get flying across a lake or in powder and it'll drop to about 140. This is stock cooling system, no extra coolers or anything.
Right around 210 the stock idiot light comes on.
