Toggled the resolution from and back to 250, no change. Tried getting the map from the PCV again, still screwed. I decided to try from the start again. I loaded my base non-auto tune map and when the PCV noticed auto tune was connected it prompted me to add auto tune tables. Everything good so far....fuel table looked normal. Added Afr targets, saved and sent to PCV. Still looked ok. Put on 100 miles, trim tables showed trim values and fuel table still looked normal. Accepted, sent map and saved. Still looks good. Target Afr tables no longer show "invalid", but reads "basic". Thinking this has to be what caused the problem??? So....whatever was going on must gave been self inflicted. When I made my first map, I added the Afr table values before hooking up to the PCV, wondering if this caused the issue, instead of letting the software ask me to add the auto tune tables first. Anyway seems good now, thanks for trying to help!
Aweseome... glad I could help.
