FlyinA
- Feb 8, 2009
- Beaver Dam, WI
- 2015 Apex SE
I'm considering Hygear front and rear as you've done for my '15 SE. Curious on your impressions so far. Happy? Money well spent?I ordered one from hyGear being built as we speak. They said about 3 weeks turn around. I also order the dual pressure kit for the fronts. They don't do the revalve any more on the rear shock i believe. I can update later after it snows. Any one interested in the mega float it only has 400 miles.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
i cant give u an honest answer yet. with the bad luck of not having enough snow yet to even put any miles on. we got alittle snow yesterday if we still have it saturday ill be riding . ill keep u posted.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
got a little riding time in, saturday hit the lake felt great but was smooth, today went trail riding and was good. I currently have 65 psi ride height and 175 bottom on my fronts, over all good but going to try 60 psi next time to try to keep the skies down. Going over bumps no problem. Back is good and arms only hurt from hitting the flipper lol. Far as the rear axis shock, awesome. Didn't bottom out at all and best of all didn't have to worry about the rear shock blowing out or leaking air. Need more ride time to see if it was worth the upgrade but so far i like it
FlyinA
- Feb 8, 2009
- Beaver Dam, WI
- 2015 Apex SE
^ Are you using Hygear coil over shocks on the front as well? Sounds like you're using the gas shock mod instead?
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
using stock floats up front with hygear pressure fronts and axis rear^ Are you using Hygear coil over shocks on the front as well? Sounds like you're using the gas shock mod instead?
