corey miskolczi
- Dec 10, 2007
- Saskatchewan
- sidewinder btx, viper mtx, venture tf
How long does it take to pull engine on 09 rs venture? What part of the exhaust do i have to take apart.
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
Before you pull your engine, what exactly are your symptoms. The reason I ask is to determine if the fault lies with the starter motor or with the starter clutch. If the motor is gone then you must move engine forward to remove starter motor. If the starter clutch is at fault that is removed through the stator side of the engine. If the engine cranks but the starter sounds like it is disengaging every time the engine fires before it can start it is the starter clutch that is the problem. If after checking the starter wiring and there is still no cranking then the starter motor is the problem. Just want to make you aware of what could be happening.
It will take about 8 hrs..in and out.
corey miskolczi
- Dec 10, 2007
- Saskatchewan
The starter does not turn over at all. I put direct power to the starter and still nothing. Where does a guy disconnect the exhaust ?Before you pull your engine, what exactly are your symptoms. The reason I ask is to determine if the fault lies with the starter motor or with the starter clutch. If the motor is gone then you must move engine forward to remove starter motor. If the starter clutch is at fault that is removed through the stator side of the engine. If the engine cranks but the starter sounds like it is disengaging every time the engine fires before it can start it is the starter clutch that is the problem. If after checking the starter wiring and there is still no cranking then the starter motor is the problem. Just want to make you aware of what could be happening.
Handy
- May 12, 2005
- Anola Manitoba
To pull the engine you need to remove the seat, fuel tank to get access to the exhaust. You then need a tool to remove the motor mounts. See the info under cam chain tensioner replacement at the top of the RS forum. That should get you going.
wiharley02
- Dec 1, 2014
- Oshkosh/Neenah, WI
- 2006 Nytro, 2005 Vector
I just pulled the starter on a 2006 Nytro without pulling the engine. Might be the same on your newer sled. Here is what i did:
Remove airbox. Remove battery and holder. Remove primary, for ease of access to front right motor mount bolt. Remove front right motor mount bolt. Remove front left motor mount bolt. Remove brake disc for ease of access to rear motor mount bolt. loosen but didn't remove rear mount nut, on the long bolt that goes all the way across. Remove bottom access cover, remove oil filter. Remove starter lead on starter, remove 2 starter bolts. Lifted engine on the front by the two ears that have holes in them, with ratchet straps. Engine rolls up and forward. But found that i needed to also unbolt the front right mount from the engine to get just enough extra movement on the motor to slide the starter out from underneath the motor, through the oil change service hole in the bottom.
I think there might be enough similarities in the RS chassis over the years to do the same on yours.
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
I wonder also if the starter can't be removed by taking out the driveshaft and the heat exchanger?
corey miskolczi
- Dec 10, 2007
- Saskatchewan
Still waiting for the starter to arrive before i start surgery lol. Thanks for the heads upI just pulled the starter on a 2006 Nytro without pulling the engine. Might be the same on your newer sled. Here is what i did:
569jason
- Aug 22, 2007
- Fort Wayne,IN
- 2011 RS VENTURE GT
Hey guys I was wondering how many miles are on these sleds that have the starters go out?
corey miskolczi
- Dec 10, 2007
- Saskatchewan
This sled has 1780 miles. The first actual repair i will make on a yamaha. We own a lot of yamahas so i cant complain
Handy
- May 12, 2005
- Anola Manitoba
There have been instances where starters have stayed on after start up causing them to self destruct. Rockmeister has made indicator kits to show if the starter was still engaged.
corey miskolczi
- Dec 10, 2007
- Saskatchewan
Well guys i finally recieved that starter and installed it yeasterday. Purrs like a kitten. If anybody else has to put a starter in a rs venture, you do not have to remove anything besides the air box, front motor mounts, steering linkage. oil filter.. There is enough give in the exhaust to tilt the engine so you can get the starter out. It helps with 2 people. The starter bolts are difficult to install but overall went smooth.
darren matchett
- Dec 27, 2015
- New Brunswick
- 2009 Venture TF
Hi Corey, I have a 2009 Venture TF with a bad starter. Is this the same sled that you changed the starter on without removing the motor? Any problem accessing the starter bolts doing it from the oil filter hatch opening? Any help is appreciated, dealer is telling me they only do it via motor removal which is very labor intensive. Thanks, DarrenWell guys i finally recieved that starter and installed it yeasterday. Purrs like a kitten. If anybody else has to put a starter in a rs venture, you do not have to remove anything besides the air box, front motor mounts, steering linkage. oil filter.. There is enough give in the exhaust to tilt the engine so you can get the starter out. It helps with 2 people. The starter bolts are difficult to install but overall went smooth.
Sleddog1
- Sep 19, 2015
- Niagara Falls
- 2000 SXR 700
2008 Vector GT 40th Anniversary
2014 Viper LTX
Don't pull the engine!! I just replaced 2 of them on my vector. Remove front engine mounts and air box and battery box. Put a crow bar on a safe spot on the block and pry forward. It will drop out. I just burned out 2 starters to realize I have a problem with the starter clutch and now I'm wondering how to remove the side casing to get at it. Fun fun fun. $$$
darren matchett
- Dec 27, 2015
- New Brunswick
- 2009 Venture TF
Thanks Sleddog, but too late for me, already pulled my engine. After speaking with Corey from above thread, I tried taking out the starter from the bottom, but it was a no go. I have the fuel injected venture and his was the carb model. I lifted the front of motor as much as possible and still couldn't drop the starter. Been running yamahas for about 24 years and this is really a poor design for changing a starter. For your one-way bearing, I believe you have to take that side cover off the engine so lightly need the engine out for that as well. Good luck and thanks to you and Corey fo trying to help.Don't pull the engine!! I just replaced 2 of theml drop out. I just burned out 2 starters to realize I have a problem with the starter clutch and now I'm wondering how to remove the side
