hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
The OEM heat shield on mid pipe is starting to become a more frequent failure as they age. For what it is the OEM one is a bit pricey at around $220 list and they don't seem to hold up very long even when new. Been working on a better quality one in the offseason. Finally got my cardboard templates converted to aluminum last week. Will certainly take a few revisions til I get it where I want it but its getting there. Below is a sneak peak.
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I needed 2 replacements on my 17 with 11,000miles
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
Nice work! This will make a nice upgrade when you get these to market. It will be on my shopping list.The OEM heat shield on mid pipe is starting to become a more frequent failure as they age. For what it is the OEM one is a bit pricey at around $220 list and they don't seem to hold up very long even when new. Been working on a better quality one in the offseason. Finally got my cardboard templates converted to aluminum last week. Will certainly take a few revisions til I get it where I want it but its getting there. Below is a sneak peak.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
Just wondering how this is coming along.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Just wanted to let you know this product is still alive. I plan to have them finalized for upcoming season.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Will they be easily hand-bendable? I can see that there would likely need to be more room for the O2 sensor in my 3" TD Super Quiet muffler. I had to bend in part of the stock heat shield a bit toward the pipe as well to give more clearance.Just wanted to let you know this product is still alive. I plan to have them finalized for upcoming season.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Is that going to have enough clearance for those that are running an O2 sensor in an aftermarket muffler such as a TD 3" Super Quiet? I had to bend in my factory heat shield to give clearance for the wires coming out of the O2 sensor.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I have not given an consideration to that option yet. Just wanted to nail down stock set up to start.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Looks nice!
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
It does look good, but IMO it needs to "float" like the stock one does to absorb vibration or it will crack prematurely. Notice how the stock shield has the floating washers on it with "cushions"?
One thing I found out is that when it can't "float and absorb the vibration", is they crack & break. They need to be dampened somehow from the vibrations of the pipe thats moving with the engine movement & vibration. Exactly why the flex pipes break is the vibrations and movements. The shield should not be mounted solid to the exhaust pipe and turbo. Just my experience with the shield dilemma issues.
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Real Good Point .. So are you thinking the factory hardware really needs to be used ???It does look good, but IMO it needs to "float" like the stock one does to absorb vibration or it will crack prematurely. Notice how the stock shield has the floating washers on it with "cushions"?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I understand your concern and have been back and forth on it as well. All 4 mounts
I've been back and forth on the "float". All 4 mounts are on the pipe. For sure if 2 mounts were on pipe and 2 on the turbo then there would need to be some isolation mounts. Lots of heat shields on atv and cycles are fixed on headers with no float so I figured we try simple first. Time will tell.It does look good, but IMO it needs to "float" like the stock one does to absorb vibration or it will crack prematurely. Notice how the stock shield has the floating washers on it with "cushions"?
- 6K
