Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Yes
Fleecer
- Jun 13, 2014
- 2019 SRX
I had this for 2 seasons now without issue. Definitely softens suspension for a pusher ride. I weigh 165 and this was a good investment imo.
yamaha06
Might have to be something I look into. The only thing I am worried about is when I take the wife out which isn't too often it maybe way to soft. How does it handle in the really rough trails?
Fleecer
- Jun 13, 2014
- 2019 SRX
Bear in mind, I put black factory pucks on soft plus the BOP gadget to make things super plush. Rough trails I turn one of the factory black pucks to medium and leave the other on soft. When I ride the wifey I put both black factory pucks on medium. Then when i go out alone again both black factory pucks to soft. The BOP gadget stays in there all the time. Hope this helps.
yamaha06
Sounds good, thanks for the info, I am going to have to give it a try. Would like to have a little bit of sag, seems to soak up the trail junk a bit better. Thanks again.
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
I just installed this kit on my sons 16 viper RTX-SE, he's 150 dressed. After install there was a noticeable sag or sit in before he even sat on it. To start out we have the blocks set on 3 and we'll go from there. This suspension has the QS3's, so I can tune as needed. Upgraded the center shock to a hygear H1 custom QS3 as well. Its going to take some tuning but we'll get there with all these upgrades.
tony lawhead
- Jan 25, 2017
- kingsley mi
- 2015 viper
have this on my sled with axis shocks works perfect thx travis
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Does the sled now squat when you take off, triangulate better when you punch it?
Fleecer
- Jun 13, 2014
- 2019 SRX
I had already removed the coupler blocks for maximum transfer. Didn't really notice if the BOP gadget contributed to more.
SpecRTX
- Mar 11, 2006
- Speculator, NY
- 2018 Thundercat
Anymore feedback as it relates to transfer with this product? Specifically for the 137s.
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
Bringing this thread back up. Any more feedback on it?
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Did they change/improve the torsion springs on later models? Jaret seems to recommend an aftermarket torsion blocks to get a 4th setting for saddlebaging etc... and he doesn't look big.
What do you guys do? Less or more?
HABS 1
- Oct 22, 2015
- corunna,ontario
my 21 xtx sagged way to much for my likeing, im 255 in shorts n tee, put those bop spring adj blocks in to get tge 4 th setting and cranked the center spring damn near to max and it seems good now, bout inch sit in or so, might put a sting ray on center if need moreDid they change/improve the torsion springs on later models? Jaret seems to recommend an aftermarket torsion blocks to get a 4th setting for saddlebaging etc... and he doesn't look big.What do you guys do? Less or more?
- 11K
