doc 4 stroke
just recieved a set of fox evols for my phazer looking to you guys for a base setting to shorten my learning curve ! two riders 1 is 150lbs and the other 220 lbs. anny help would be great !
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
Lucky guy.Remember to always do Evol chamber first.Evol always more PSI than main.Try 100 psi Evol and 75psi in main.
I rode with 75 psi in my regular fox floats up front and i though it was to stiff.. now im trying 65.. fells better and more responsive (an mtx without swaybar)..
75 i feelt was just to hard when landing and as the evol works you should be able to runt the main shock at lower psi and the pressure in the evol chamber helps prevent bottoming out.. so Id start with 60 if I was you..
Makes sense.
- 47K
