savan2000
my battery went dead this summer in strorage,as i forgot to put trickle charger on. so i put it on trickle charger for couple weeks and put it back in sled and was fine. now after sitting for 2 weeks its dead again. Can this battery be used and be reliable again?
LJ 452
It's probably toast, but I you have access to an Optimate or similar charger that can desulfate and revive it you MAY be able to get it back. On the other hand, the cost of the battery and the consequence's of it dieing while out on a trip may not be worth the risk. $115.00 for the OEM.
Nytro Nork
I have in the past had the same issues with my 4Wheelers. Ive had good luck and bad luck sometimes it lasted months and sometimes days, but that was in the summer temps. Finally i got tired of boosting and just replaced it. The battery for the Nytro shouldnt be anymore than $100.00. If i was you i would replace it and then its one last thing you have to worry about and it will be less downtime when the snow finally gets here.
booxr800
I have the same issue and am just going to replace it. Going with a smaller lighter one too can cut upto seven pounds. The mountain guys have been doing this with pretty good luck so far.
savan2000
thanks everyone. I will replace.
gapl1953
Remember it's hard to push start a Nytro.
Greg
Greg
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
savan2000 said:thanks everyone. I will replace.
Good choice and piece of mind for under a 100 bucks....
- 11K
