How long can my new RX-1 set with out putting it on a battery charger.? also would I need to have it on 2 amps and 12 V...Thanks...
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
I would not leave it alone too long. You are better off storing your battery in a warm environment. Cold and time can wreak havoc with a battery. I have a Battery Tender and that works great. I also have a trickle charger which works good also the only thing is with the trickle charger you do not want to leave it on constantly but the Battery Tender can be left on and it maintains the battery at full charge without overcharging.
JDKRXW
This is the answer to your question.
http://www.accumate.co.uk/it010003.html
They're pretty cheap, and sold in many places (Yamaha dealers have them), and they can rejuvinate abattery that you thought was junk (worked for me, and paid for itself on one motorcycle battery).
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I have an optimate also. I rotate it around to all my stuff that needs charging for about a week at a time: Vette, VMAX, Quad, Motorhome and Warrior.
Tork
Like the guys above said the optimate is a great charger at your Yammie dealer for around $50. It can even desulfate damaged batteries. the 05 models at least, have a plug to the front of the oil tank that plugs right in to this specific charger.
TO ANSWER YOUR QUESTION. Batteries of this type will loose 1 or more% of the charge each day.
If you let a battery discharge the plates will sulfate.
If you let a discharged battery sit in the cold, it can freeze and crack.
SOOOOOOO, a charger, particularly the one in the link above is the way to go. Just my own little opinion here :mrgreen:
Thanks guys''' I will look in to one them 'Optimate chargers' at my dealer...
kinsound
I purchased one of those chargers . My battery was completly dead... I let it sit for 3 days and it did nothing...I put the trickle charger on for 15 minutes and it got some charge... so I brought it back and got another one thinking it was defective.. It has been on for 48 hours and still no charge.. any suggestions? It never goes into the "test" mode as the directions say it will nor does it say it needs to desulphate
Tork
a link to another thread of a battery that WAS saved
http://www.rx1.info/viewtopic.php?t=7309
Sorry kinsound that it did not work out for you. But at least your new charger should keep your new battery healthy for several years.
kinsound
No need to be sorry.. But thanx... Not a bad deal buying an 03 RX1 silver edition loaded with all sorts of extrasand only 500 miles on it for $5000.00. so i guess 80$ for a new battery is a burden i must bear.. But you are right a good charger for the future!! THINK SNOW!!
jimmie d
I used my charger (Jr. Battery Buddy) for the first time and light stayed red for only 5 minutes, than green. I do start mine twice a month during the summer. These stock batteries really hold a charge good. My tractor took a full day.
Jim
Jim
