Battery relocate
hellflyer
Georgtown ONT. Canada
Canada
2020 sidewinder ltx se
I've been thinking about a battery relocate for some time now and since I have a turbo there's now air box and easy access to mount it low in front of the engine! I see no cons to this as I'm 270lbs and ride with a trunk bag most of the time, so weight balance will likely be better for me. Second is the battery will be warmer after riding which is always better and it'll have way shorter cables.
Is there any cons to this that anyone can see?
I can't think of any. Good idea
it makes a lot of sense. Just the ease of getting to the battery would be and issue. Unless you set up booster extensions if ever needed.
Have you actually measured the distance from the rear of the sled to the front where you want to place it. Not sure if 8 inches would make a huge difference. I just looked at it with the engine out of the sled. I don't have the time to measure, new season opening up. Dam early spring. Cottage renovations.
Yes booster extenions would be a must like the apex had and my apex had the original battery for 5 yrs and never had any issues buried under the airbox.
I leave the seat bolt off using just the spring clip to hold it on. Easy to get at.
Ya! But I'm going to mount it in front of the the motor to keep it up right like it should be and warm when riding.
My battery actually leaked on one ride. Good thing I checked out everything after the ride, had battery acid on the solenoid and al over the bracket. Hasn't leaked since though.
