hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
There have been a few orders coming in with both the fuse box relocate kit and also a fan reverse harness ordered. You do not need to order a fan reverse harness along with the fuse relocate kit. The kits include a jumper harness to make the connection to fan, and we can supply this harness in reverse or std. We've refunded those that paid extra and I will have to add a note in the online store to help clarify. Not a big deal, but just wanted to make a not of it.
In summary....if you buy the fuse box relocate kit you can also get the fan reverse at no extra charge!
Just added the Fuse Box Relocate. I really like this! Went well. Added a stud to the plate for all my Accy grounds. Really cleaned up area and so convenient. Nice job!
Now thinking of making a little mount for PCV and Other stuff on coolant bottle.
I have my relocate kit still sitting here. I'm thinking I'll get after it sooner or later. Curious to see what you do with your spare belt?
I'm thinking about taking off that junk belt pouch from the rear and putting on the expandable tunnel bag that I have had kicking around here since late 2014...
Argo
- Dec 18, 2015
- central wis.
- 2015 Ltx le
Will this relocate kit work with the mpi turbo kit.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
yes and no. I moved mine and bolted it to the holes that were already in the belt guard. The bracket wont work but you need the fan extension. The air intake for the turbo is in the way for the bracket but you don't need it. I also mounted my fusebox on its side so its exceptionally easy to see the fuses and test them. I mounted my EABC on the coolant bottle and zip tied my gems controller to the oil return tube. Very clean look. You will need to grind a bit off the rubber snorkel on the side panel that funnels air to the clutches but that is not a big deal. Easy to do with a Zip cutter.
Argo
- Dec 18, 2015
- central wis.
- 2015 Ltx le
Super thank you for the quick response. Have a great Christmas guys and gals.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I installed one and it's a great upgrade! And best off all there's a fuse location diagram. What sucks is the Canadian dollar! $195CAN by the time I got it. But still worth it to me
CharlieAZ
- Dec 20, 2016
- Nutrioso, AZ
- 2015 Yamaha SRViper LTX DX and 2005 Yamaha Vector RS ER makeover 2017/2018
- Vail,az
- AOL
- Palmercmp0466@aol.com
I love to get on of these if they are still available. If they are , can you please provide me some details... I have a 2015 Sr Viper LTX DX... thanks Charlie
CharlieAZ
- Dec 20, 2016
- Nutrioso, AZ
- Vail,az
- AOL
I found it, and ordered it a few mins ago , are you still giving the reverse fan as part of order to members
Dont reverse the fan.I found it, and ordered it a few mins ago , are you still giving the reverse fan as part of order to membersThanks.... Charlie
CharlieAZ
- Dec 20, 2016
- Nutrioso, AZ
- Vail,az
- AOL
Ok, can you explain some why. Thanks! CharlieDont reverse the fan.
Because a fan isnt designed to push. Your sled will overheat and you will be pissed.Ok, can you explain some why. Thanks! Charlie
