freelance
- Apr 15, 2013
- Manitoba, Canada
- 2014 Yamaha SR Viper XTX SE
Just got back from a 125 mile ride where my XTX was started and shut off all day with no problems hot or cold. On my way home I noticed rpms were low at idle. When I got home I shut the engine off and tried to re-fire. It cranked a couple times....showed code p1338. Cranked it another couple of time and then the battery went dead.
I've since put it on a charger and it fired up no problem with no codes either.
Any ideas ?? Has always started hot or cold. It has not had the reflash as it didn't seem necessary. Original battery with just over 5000 miles. All cables were tight.
Maybe it just time for the battery to be replaced ??
What is the recommended replacement battery ??
Thanks !!
Thanks !!
