Bearing dimension
Tyloooor
sudbury, ON
I'm wondering if anyone has the dimensions for the lower bearing inside the chaincase....PT# is 93306-205A9
I can find the dimensions for PT# 93306-20592-00 which is;
Notes: Sealed one side only
.983"ID x 2.048"OD x .590"W
25mm x 52mm x 15mm
are they the same or close? does anyone know?
Ill look at work tomorrow. Will try to get ba k to you asap. It can be sealed both sides, just have to remove one seal before install. Im sure timken or FAG has them.
I am pretty sure it is a 6205 bearing. There is all the part numbers in a sticky post. I think it is at the top of the page under FAQ's. Just went through getting spare bearing from a bearing dealer. There is only one you have to get at the Yamaha dealer and that is a 6206 with a 28mm bore instead of the standard 30mm bore. Rule of thumb for bearings is the first 2 numbers is the series of bearing and the last 2 numbers is the diameter . Take the last 1 or 2 numbers and x 5 gives you the bore in mm. There are 6205's that are 1" or 25.4mm and another one that is 25mm or .984"
