STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I am changing the left side upper drive shaft bearing om 17 Sidewinder. The bearing I removed is a 6206RD 28mm bore diameter. I ordered a FAG bearing from an online source. That bearing is a 6206RSR 30mm bore diameter.
Every 6206 bearing I look at has a 30mm bore. I cant find an aftermarket equivalent for this 6206RD bearing. I cant believe the factory one is the only source. Am I wrong?
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Are those all of the numbers on the bearing seal (6206rd)doesn't make any sense as the 06 in 6206=30mm bore.should be single rubber sealed one side only.assuming new bearing fits loose or you had measured shaft&it was 28?I am changing the left side upper drive shaft bearing om 17 Sidewinder. The bearing I removed is a 6206RD 28mm bore diameter. I ordered a FAG bearing from an online source. That bearing is a 6206RSR 30mm bore diameter.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
New bearing is loose. I then measured the old bearing at 28mm. That’s all the numbers on the seal
Brotherdan
- Sep 8, 2017
- Belmont,maine
Who is the mfg of original bearing?Yamaha has been known to use some special size bearings but generally coded as special by the bearing number.was the own bearing big money?New bearing is loose. I then measured the old bearing at 28mm. That’s all the numbers on the seal
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Do you mean the Jackshaft bearing behind the secondary clutch?
Are you sure it's 28mm cuz all my cross numbers show 30mm?
I'll check my new Yamaha bearing tomorrow & measure it.
ID=30mm OD=62mm W=16mm
6=Bearing type which is a deep groove-single row
2=Bearing robustness 9 is thin, 4 is heavy, 2 is light
06=Bore size, so 00=10mm, 03=17mm, over 03 is 5 times the # so 06=30mm
RS=contact rubber seal
RD=extremely light contact seal (a little less heat at the contact of the race)
I thought it needed a 2 before the RS or RD to be double seals, but apparently not
The RS is ok, but 2mm is A LOT
Brotherdan
- Sep 8, 2017
- Belmont,maine
So it is in fact a special bearing from what I've found,see post by ruffryder reference jackshaft bearing,he found the same thing 28mm id (which makes no sense )but seems to be a yamaha only bearing &he had to purchase from yamaha,another oddball bearing to add to the list.Who is the mfg of original bearing?Yamaha has been known to use some special size bearings but generally coded as special by the bearing number.was the own bearing big money?
Brotherdan
- Sep 8, 2017
- Belmont,maine
Also found it's yamaha only&articcat is differentSo it is in fact a special bearing from what I've found,see post by ruffryder reference jackshaft bearing,he found the same thing 28mm id (which makes no sense )but seems to be a yamaha only bearing &he had to purchase from yamaha,another oddball bearing to add to the list.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
it is a Koyo bearing. the only other markings are "4YD" on the inner race. Ordered one from Yamaha today. In the Yamaha fiche it is listed as their part number then 6206, misleading......
Maybe 4YD stands for " For Yamaha Driveshaft"
The chaincase side is an open 6206 bearing.
The Cat shaft is different to accommodate their secondary.Also found it's yamaha only&articcat is different
- 15K
