Attak-Firecat
On the Apex skid: How do the two large wheels on the top of the swing arm come off? Shouldn't they just slide off like the plastic bushings do?
Kaz
Just tap them off with a hammer, put the suspension bolt back in the shaft and tap the head of the bolt and it should come off the shaft. Keep track of the spacer/washers when it comes apart.
Kaz
Kaz
Attak-Firecat
ok, thanks. it's taking some mighty whacks for the wheels to budge. yikes.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
mine were rusted on bigtime...let some penetrating oil set on them overnight....the bearing rusts alot where its seated.
i beat mine off finally and will be replacing them anyway.lol
Dan
Dan
blustar
- Mar 11, 2009
- Manitoba
- members.shaw.ca
- Yamaha Apex and RS Vector
Rocker,, what are you replacing them with.. factory - stock ones or anything else?
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
BE CAREFULL! If you beat then off too hard you could go blind. Glad you're back DAN!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
sticking with stock 7"....i was considering 7.5" to allow more shock eye clearance but dont want to loose clearance at studs,so just going with stock wheels now.
Dan
Dan
