wacker
I'm new to Yamaha clutching and am unsure how high my belt should sit in my secondary
On my doo's i always set it so the top cogs would be above the sheaves but don't think i could get my viper that way
Any ideas??
Any ideas??
subaru2006
- Nov 1, 2008
- Minooka, IL
- 2016 Polaris SBA
I'll have to look in the book but I believe its 1.5mm above to .5mm below
Subaru2006
Subaru2006
You just want the track to creep when up on stand. Mine is a bit above the sheave. It is set by removing secondary and you will see three screws with washers under them. The thickness of washer determines your belt height. Less= lower If I remember right.
wacker
Thanks i guess mines just about right then
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
There are 2 shim sizes .5mm and 1mm you want the belt .5 -1mm above the secondary. There are 3 screws and the shims have to be all the same on all 3.
