DeepFrz
Currently in the UP on a snowmobile trip. First day out riding today and my XTX began to shred a belt so we stopped and through my spare on. Ever since the belt has been slipping and smoking. Any ideas on what could be causing this? I confirmed it's the right serial number and is on the right way.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Oil on the belt, was it a new one.
DeepFrz
Was a brand new belt. Didn't feel oily at all though
APEX 06
- Apr 30, 2009
- Sheboygan, WI
I would pull the belt and wash it in hot water and soap if u have any. Then let it dry over night. Are both clutch moving
DeepFrz
What do you mean by moving?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
Opening and closing freely nothing sticking.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
How many miles on clutchs? I just had the same issue with a lot of miles on my clutches. If I went over 3/4 throttle belt would slip. I replaced bushing in movable sheeve, cover bushing and the six spider bushings in the primary clutch. All had wear on them and would not allow clutch to open and close smoothly. This cured my issue.
DeepFrz
Only about 3000 on the clutches
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Mine has more than twice that in miles. You could have cords stuck in your clutches from blown belt. I would pull primary cover off and check it. And make sure nothing stuckin secondary.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Is your plastic skid plate still there below engine? I have seen those fall off and tons of snow gets in clutches then.
gitrdun
- Mar 15, 2007
- north of superior
- 07 Attak
When is it slipping and smoking, at startoff, higher speeds, or all the time? Is the belt sitting properly on your secondary? it should be very close to even with the top of the sheve(edge).
DeepFrz
Usually at higher RPM going through deeper snow. Belt is seated properly on the secondary. It's just strange because the first belt this morning wasn't slipping at all. Although that's the 2nd belt I've blown in 2 seasons which is really strange for a Nytro. I put on a 2" Challenger track last season but I wasn't aware I needed to do anything to the clutches.
Sledguy89
Are you running stock gearing still? Having the same issue but just seems like it slipping an revs high when trying to lay the power down. Jus swapped to 1.75
DeepFrz
Just thought I'd update you guys on the real issue, somehow I lost my skid plate on the first day of riding (pos plastic rivets). Now it's time to order an aftermarket plate. Any recommendations?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
http://www.mountaintechindustries.com/
Mountain tech skid plate is what you need. Saves the bottom of your engine and heat exchanger in case you hit something.
Tim
Tim
